I’ve followed the instructions at https://github.com/mike-grant/haaska/wiki. 2-3 times actually:
First go, used different emails for AWS than Alexa. (Arrg)
On the second go, the test script worked and skill finally showed up after I added intents and utterances. Skill was “Dev” but now also under “private”. But no new devices are discovered and no new commands. I limited the HA config so only a couple devices would show up in the test script.
Third-ish time, I tired other regions for the lambda code. I’m near Vancouver, Canada and so far I have apps in us-east-1(original) , us-west-1 (failed) and us-west-2 (tests successfully). Same results in Alexa.
Is there more to switching regions than copying the code and ARN id over?
Just what are the finished steps for the Alexa Skill? I just guessed at the intents stuff but no idea if that is causing trouble. Any other definitive way to debug this?
HA debug info showing successful test:
2020-05-12 14:26:13 DEBUG (MainThread) [homeassistant.components.alexa.smart_home_http] Received Alexa Smart Home request:
'directive':
'header':
'namespace': 'Alexa.Discovery',
'name': 'Discover',
'payloadVersion': '3',
'messageId': '1bd5d003-31b9-... '
'payload':
'scope':
'type': 'BearerToken',
'token': 'access-token-from-skill'
2020-05-12 14:26:13 DEBUG (MainThread) [homeassistant.components.alexa.smart_home_http] Sending Alexa Smart Home response:
'event':
'header':
'name': 'Discover.Response',
'messageId': '7a3c8d08-dcf9-47d8...',
'payload':
'endpoints': [
'displayCategories': ['SWITCH'],
'cookie':
'endpointId': 'switch#baskets_drive_house_beds',
'friendlyName': 'Baskets, drive & house beds',
'description': 'switch.baskets_drive_house_beds via Home Assistant',
'manufacturerName': 'Home Assistant',
'capabilities': [
'type': 'AlexaInterface',
'interface': 'Alexa.PowerController',
'version': '3',
'properties':
'supported': [
'name': 'powerState'
'proactivelyReported': True,
'retrievable': True
'interface': 'Alexa.EndpointHealth',
'version': '3',
'properties':
'supported': [
'name': 'connectivity'
'retrievable': True
'interface': 'Alexa',
'version': '3'
'displayCategories': ['SMARTLOCK'],
'cookie':
'endpointId': 'lock#yale_yrd226_tsdb_66271911_door_lock',
'friendlyName': 'Deadbold',
'description': 'lock.yale_yrd226_tsdb_66271911_door_lock via Home Assistant',
'capabilities': [
'interface': 'Alexa.LockController',
'version': '3',
'properties':
'supported': [
'name': 'lockState'
'retrievable': True
'version': '3',
'properties':
'supported': [
'retrievable': True
'version': '3'
