After 0.88 update haaska has stopped working, going to the aws console and trying to run the test I receive this message: “errorMessage”: "404 Client Error: Not Found for url: https://XXX.duckdns.org:8123/api/alexa/smart_home "
Hrm… that’s strange. I have everything up to date right now and it’s working.
What version of Home Assistant were you using before?
Are you still able to reach it over the web if you go to https://xxx.duckdns.org:8123?
I always updated HASSIO to the latest version and until the last update everything worked, I can reach it without problems
maybe I found the problem, two more tests
