Haaska help please?
As I understand it, haaska runs on amazon computers and only needs to access HA through its api. (needs to be SSL) You can get anyone to make the zip files for you with your url / password and then you can upload it.
Is it possible to run the make file on my mac. I get this error when I try that:
xx-MacBook-Air:~ xx$ /Users/xx/Downloads/haaska-master/haaska/Makefile ; exit;
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 2: SHELL: command not found
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 9: haaska.zip:: command not found
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 10: BUILD_DIR: command not found
usage: mkdir [-pv] [-m mode] directory …
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 11: BUILD_DIR: command not found
usage: cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file target_file
cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file … target_directory
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 12: BUILD_DIR: command not found
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 12: pip: command not found
/Users/xx/Downloads/haaska-master/haaska/Makefile: line 13: BUILD_DIR: command not found
zip warning: name not matched: Library/Application Support/Google/Chrome/RunningChromeVersion
zip warning: name not matched: Library/Application Support/Google/Chrome/SingletonCookie
zip warning: name not matched: Library/Application Support/Google/Chrome/SingletonLock
zip warning: name not matched: Library/Containers/com.apple.accessibility.heard/Data/Documents/iChats
