Good morning,
I installed haaska and it works perfectly
Now I would like to ask if it was possible to tell alexa the status of the sensors.
It would be possible ?
How to please.
Thanks, Alberto
Good morning,
How to please.
Thanks, Alberto
Hi Alberto, Are you asking how to get HA to export a sensor to Alexa (via Haaska)?
no wmaker,
I wish I could tell alexa the status of the lights if on or off and / or the temperatures in the rooms saying
For example: âalexa, tell me the temperature in the kitchenâ
Take a look at the following to see if it helps. Although the subject is in regards to HA Cloud, you will find a user that shows his configuration that was used with Haaska
thanks wmaker !!
I currently solved by creating a script.
The only problem is that I have to say âalexa, turn on informationâ and alexa lists the sensor statuses for me
All you need to do is set up a routine to ask the question in whatever way you want and link it to âalexa, turn on informationâ.
Very good Bobby
