🪥 Habitica: Complete toothbrushing tasks on your Habitica Dailies list
Automatically mark your morning and evening toothbrushing dailies as complete when your toothbrush usage is detected.
This is an example automation created for the Home Assistant documentation… This blueprint requires an Oral-B toothbrush.
blueprint:
  name: "Habitica Daily: Complete toothbrushing tasks"
  description: "Automatically mark your morning and evening toothbrushing dailies as complete when your toothbrush usage is detected."
  author: tr4nt0r
  homeassistant:
    min_version: 2024.8.0
  domain: automation
  input:
    toothbrush_state:
      name: "Toothbrush usage sensor"
      description: "Select the sensor that monitors the toothbrush's status. The automation triggers when the sensor detects the toothbrush is in use (status 'running')."
      selector:
        entity:
          filter:
            - domain: sensor
              integration: oralb
    habitica_dailies_list:
      name: "Habitica dailies task list"
      description: "Select the Habitica dailies task list where the morning and evening toothbrushing tasks are tracked."
      selector:
        entity:
          filter:
            - integration: habitica
              domain: todo
    actions:
      name: "Morning routine pre-actions"
      description: "Optional actions to run before completing your morning routine (e.g., check for unfinished Yester-Dailies and start the day. Your morning routine won't be tracked if you haven't started the day)."
      default: []
      selector:
        action: {}
    wakeup_routine_title:
      name: "Morning toothbrushing task"
      description: "Enter the name of the Habitica daily task for brushing your teeth in the morning."
      default: "Brush your teeth in the morning 🪥"
      selector:
        text:
    morning_time:
      name: "Morning routine time window"
      description: "Specify the time range during which you usually do your morning toothbrushing routine. You can add additional or change conditions if needed."
      default:
        [{ "condition": "time", "after": "05:00:00", "before": "12:00:00" }]
      selector:
        condition:
    bedtime_routine_title:
      name: "Evening toothbrushing task"
      description: "Enter the name of the Habitica daily task for brushing your teeth in the evening."
      default: "Brush your teeth before bed 🪥"
      selector:
        text:
    bedtime_time:
      name: "Evening routine time window"
      description: "Specify the time range during which you usually do your evening toothbrushing routine. You can add additional or change conditions if needed."
      default:
        [{ "condition": "time", "after": "18:00:00", "before": "23:59:00" }]
      selector:
        condition:
mode: single
triggers:
  - trigger: state
    entity_id: !input toothbrush_state
    to: "running"
    for:
      hours: 0
      minutes: 0
      seconds: 10 # Time delay for debouncing to avoid false triggers
actions:
  - choose:
      - conditions: !input morning_time
        sequence:
          - action: !input actions
          - action: todo.update_item
              item: !input wakeup_routine_title
              status: completed
              entity_id: !input habitica_dailies_list
      - conditions: !input bedtime_time
        sequence:
              item: !input bedtime_routine_title
              status: completed
