✅ Habitica: Create To-Do when dishwasher finishes its cycle
This is an example automation created for the Home Assistant documentation.
It automatically creates a Habitica to-do when the dishwasher finishes its cycle (based on state of a binary_sensor). A due date can be set with a template, by default todays date will be used as due date.
blueprint:
  name: "Habitica To-Do: Empty the Dishwasher"
  description: Automatically create a Habitica to-do when the dishwasher finishes its cycle.
  author: tr4nt0r
  homeassistant:
    min_version: 2022.8.0
  domain: automation
  input:
    dishwasher_sensor:
      description: "Select the sensor that indicates whether the dishwasher is running. The automation will trigger when the sensor changes from 'on' (running) to 'off' (finished)."
      selector:
        entity:
          filter:
            - domain: binary_sensor
              device_class:
                - power
                - running
    habitica_todo_list:
      name: "Habitica To-Do List"
      description: "Choose the Habitica to-do list where the **Empty the Dishwasher** task will be created."
      selector:
        entity:
          filter:
            - integration: habitica
              domain: todo
              supported_features:
                - todo.TodoListEntityFeature.CREATE_TODO_ITEM
    todo_title:
      description: "The title for the Habitica to-do."
      default: Empty the dishwasher 🥣🍽️
      selector:
        text:
    todo_description:
      name: "To-Do Description"
      description: "Optional description for the Habitica to-do item."
      default: "Empty the clean dishes from the dishwasher and load any dirty dishes that are waiting."
      selector:
        text:
          multiline: true
    todo_duedate:
      description: "Set today's date as the due date. To set a future due date, such as tomorrow, you can use the following template: `{{ (now().date() + timedelta(days=1)) }}`."
      selector:
        template:
      default: "{{now().date()}}"
    actions:
      description: "Additional actions to run after creating the Habitica to-do, like send a notification to your mobile."
      default: []
      selector:
        action: {}
mode: restart
triggers:
  - trigger: state
    entity_id: !input dishwasher_sensor
    to: "off"
    for:
      hours: 0
      minutes: 0
      seconds: 10 # Time delay for debouncing to avoid false triggers
actions:
  - action: todo.add_item
      item: !input todo_title
      due_date: !input todo_duedate
      description: !input todo_description
      entity_id: !input habitica_todo_list
  - action: !input actions
