Beginning of the week I got interest in a project called Habitica:
“Habitica is a free habit building and productivity app that treats your real life like a game”
4 days later I find myself coding my first simple integration for Hass:
enjoy
enjoy
Hello!
That’s a really cool idea. One thing that might be interesting as well is providing a service to create tasks. I am thinking of use cases like when the washing machine is finished to create a task for that or check it off (exact name match would probably work) when the humidity in room x rises
Cheers Hannes
P.S.: consider sending in a pull request
True, I really like the idea. I will have a look into this!
About the pull request: I would have to set up the testing first… looks time consuming
(will see if I can find the time)
PS: How do you track your washing machine
I am using a template sensor to read the current power consumption. If it’s above 0 the machine is in standby or active.
https://github.com/cyberkov/home-assistant-config/blob/master/sensors/homematic.yaml
Cheers Hannes
Can I have the REST notify and the sensor component in one python file or do I need to create a separate notify and a sensor component?
Do I need a sensor and a notify config for this or can I put both in one? If yes, how do I do this in the best mannor?
- platform: habitica
api_user: xxx
api_key: xxx
and
notify:
- platform: habiticaSend
api_user: xxx
api_key: xxx
and than in the automation or script like this:
- service: notify.habiticaSend
data_template:
text: "Task Name"
type: "todo"
value: "0"
notes: "Notes go here."
Thanks for this, I had been meaning to get started with Habitica, and this motivated me to do so.
I created a PR to add support for more than one person, in case any one else has multiple people in their household making use of Habitica.
Nice! And I have to upvote this based on the avatar if nothing else. Wubba Lub A Dub Dub!!
I don’t use Habitica, but have had my eye on it. This makes it that much more compelling. Great work!
Awesome, thanks for contributing!
Anyone can guide me with the question I had above? I would like to create a notify function to create To-Do’s in Habitica but I’m not so sure about the best implementation for Hass.
I seem to be having trouble getting this to work.
Invalid config for [sensor.habitica]: required key not provided @ data[‘name’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/compone…
Anyone have a workaround for this?
You should add a name to your config (random name worked for me):
Thanks for that. It worked out perfectly.
