So a few days ago I installed Hacs in hass.io . After following all steps I got the community tab on the left sidebar and can access the respective page but the problem is both my Overview and Store subtabs are … empty !!
Following some other user topics which had the same issue, I tried to reload data (in my case I had to do it manually by pressing the button) but even after waiting a few hours nothing happens, it just gets stuck there forever and everything except the settings page remains empty .
Needless to say I already have restarted the server multiple times after . Reinstall also did not help !
01:42 components/frontend/init.py (WARNING) - message first occured at 00:27 and shows up 6 times
[Unknown error] - Could not load HACS!
01:42 custom_components/hacs/setup.py (CRITICAL) - message first occured at 00:27 and shows up 6 times
Overwriting integration hacs
01:42 components/frontend/init.py (WARNING) - message first occured at 00:42 and shows up 5 times
Don’t think I even got these errors on previous restarts but I guess it’s pretty messed up . For the record, Community Icon is still there on the menu, despite of the error log saying it’s removed !
I just had a problem with hacs as well. What I did was delete the hacs files in the .storage directory and then reboot HA. Worked for me you might try that. There should be about three files.
BTW when you provide logs or code samples use the </> icon at the top of the text box. It creates a text section that you can paste your code, etc into and preserve the original format. Much easier to read that way.
Yea sorry, thought the block codes were just for … code , I use them all the time when it’s yaml
So , after deleting the hacs files as you suggested, I got this :
Removing unknown panel community
02:10 components/frontend/__init__.py (WARNING)
02:10 custom_components/hacs/setup.py (CRITICAL)
Validation for hacs/integration failed with GitHub returned 401 for https://api.github.com/rate_limit.
02:10 custom_components/hacs/hacsbase/__init__.py (ERROR)
Will now try generating a new api token and see how that goes …
If you haven’t already setup the Samba share add-on do that first. This will allow you to see your config directory from a pc/mac/etc. The .storage folder is in the config directory. It may be hidden I don’t remember but easily fixed by enabling hidden files in your pc/etc file app. Anyway there will be a number of files that start with hacs, delete them. There is also a directory called hacs which will contain a file for each item you have previously installed through hacs. You could delete these files as well. Then reboot.
