HACS and mini_graph-card
Hi, Im brand new to Home Assistant, using HASSIO.
I know this question is stupid, however after using significant time to look for explanation, I need some basic help. Please bear with me.
I have HASSIO installed, working. Update to latest version. I have HACS installed, and it seem to work as expected. I can install frontends, and it looks like it is working. I have installed the frontend called “mini_graph_card”.
I have added a manual card in Lovelace. I have put in the below text in the card configuration (I have tried with many other versions also, all give the same error)
  • type: ‘custom:mini-graph-card’
    entities:
    • sensor.network_throughput_in_eth0
No matter what I put into the configuration I get the same error, like this
No card type found
    entities:
I actually belive I have missed something in the configuration of using the HACS or mini_graph_card, however I can not figure out what.
Any ideas? I know im stupid:-)
Hi and welcome to the forum. Can you please have a read of point 11 here then edit your post to correct the formatting?
Hi
formatted code would really help, as already mentioned by tom_l
Or screenshots…then we know in which part of the Lovelace you are
if you are in the lovelace card editor (where you edit the config for a single card and do not have the UI), “type” and “entities” both start in column 1 and type is not prefixed by a hyphen
type: 'custom:mini-graph-card'
entities:
  - sensor.network_throughput_in_eth0
The samples for this card on github show it with the hyphen and indented, that’s for direct copy&paste (+ adjusting indentation) when you edit Lovelace config with the raw configuration editor ( where you see the yaml for the whole board in one file, including all the formatting).
Armin
Armin-gh, That worked perfectly, as mentioned Im very new to HASSIO/Lovelase. Thanks.
Tom, I will in the future use formated code. Thanks for showing how it’s done.
