I have been running the docker home assistant version for a year or so. Watchtower updated home-assistant last night and now I am having issues with HACS and many(all?) of the integrations that I use from HACS.
I am seeing these types of errors in the logs:
home-assistant | 2022-01-11 11:38:23 ERROR (MainThread) [homeassistant.config] Package bhyve setup failed. Integration bhyve Integration 'bhyve' not found. (See /config/packages/bhyve.yaml:0).
home-assistant | 2022-01-11 11:38:24 ERROR (MainThread) [homeassistant.config] Package noonlight setup failed. Integration noonlight Integration 'noonlight' not found. (See /config/packages/noonlight.yaml:0).
home-assistant | 2022-01-11 11:38:24 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.websocket_api. Make sure all dependencies are installed
home-assistant | Traceback (most recent call last):
home-assistant | File "/usr/src/homeassistant/homeassistant/loader.py", line 639, in _load_file
home-assistant | module = importlib.import_module(path)
home-assistant | File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
home-assistant | return _bootstrap._gcd_import(name[level:], package, level)
home-assistant | File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
home-assistant | File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
home-assistant | File "<frozen importlib._bootstrap>", line 972, in _find_and_load_unlocked
home-assistant | File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
home-assistant | File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
home-assistant | File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
home-assistant | File "<frozen importlib._bootstrap_external>", line 850, in exec_module
home-assistant | File "/config/custom_components/__init__.py", line 23, in <module>
home-assistant | from teslajsonpy import Controller as TeslaAPI
home-assistant | ModuleNotFoundError: No module named 'teslajsonpy'
home-assistant | 2022-01-11 11:38:26 ERROR (MainThread) [homeassistant.setup] Setup failed for tesla_custom: Integration not found.
home-assistant | 2022-01-11 11:38:26 WARNING (MainThread) [homeassistant.components.opengarage.cover] Open Garage YAML configuration is deprecated, it has been imported into the UI automatically and can be safely removed
home-assistant | 2022-01-11 11:38:26 ERROR (MainThread) [homeassistant.setup] Setup failed for fullykiosk: Integration not found.
home-assistant | 2022-01-11 11:38:26 ERROR (MainThread) [homeassistant.setup] Setup failed for alarmo: Integration not found.
home-assistant | 2022-01-11 11:38:26 ERROR (MainThread) [homeassistant.setup] Setup failed for alexa_media: Integration not found.
home-assistant | 2022-01-11 11:38:26 ERROR (MainThread) [homeassistant.config] Platform error: switch - Integration 'bhyve' not found.
home-assistant | 2022-01-11 11:38:27 ERROR (MainThread) [homeassistant.config] Platform error: sensor - Integration 'bhyve' not found.
I tried deleting and reinstalling HACS and it seems to go ok:
wget -q -O - https://install.hacs.xyz | bash -
INFO: Trying to find the correct directory...
INFO: Found Home Assistant configuration directory at '/config'
INFO: Changing to the custom_components directory...
INFO: Downloading HACS
Connecting to github.com (140.82.113.3:443)
Connecting to objects.githubusercontent.com (185.199.108.133:443)
saving to 'hacs.zip'
hacs.zip 100% |****************************************| 728k 0:00:00 ETA
'hacs.zip' saved
WARN: HACS directory already exist, cleaning up...
INFO: Creating HACS directory...
INFO: Unpacking HACS...
INFO: Removing HACS zip file...
INFO: Installation complete.
INFO: Remember to restart Home Assistant before you configure it
But now HACS isnt’ an option on the integrations page to install. I tried clearing the cache, using a different browser, etc but it just doesn’t show as an option.
I am not really sure what else to try.
I looked over the changes in the latest release, but didn’t notice anything that I thought might break HACS.
Any suggestions on resolving this?
