Hacs being strange
I have only just noticed this… I went to do something in HACS but it is no longer on the sidebar. When I try to connect to it through mac terminals it won’t work.
If I tried to add hacs again it said there can only be one instance.
I had to use the ha terminal to remove the HACS folder
I tried to re add hacs and it still says there is a instance there.
I have it running in a vm on proxmox. Not sure weather to try a clean install on a container, but I have quite a lot of devices. Can anyone suggest anything. Bear in mind I’m not that great with coding or terminals
