Linwood, is that v4 or v5 you are working with?
Yes, it’s V5, I am new to BI and so started on V5.
I used HACS version of this. I recall when I first tried it having trouble making it appear in the available integrations lists, but your problem appears to be (if I understand) you can add the integration and then nothing happens?
My BI and HA are on different subnets on my LAN, are yours? His instructions say to set the account created to administrator and “LAN only”. Don’t use the latter if yours are different also.
And you are using the web server’s internal LAN address, not trying to use an external address (e.g. settings, web server, local not remote). Sorry if that’s obvious.
Do you know how to use Wireshark? You might monitor for port 81 (assuming that’s where you are running BI) coming from your HA IP address, and see what the session looks like – does it even connect and exchange data (reading the guts of the data may be a bit painful but you might at least see if they are talking).
You also might try adding this to configuration.yaml (if you use it; if not no idea how debug works):
logger:
default: warn
logs:
custom_components.blueiris: debug
It’s been a while but if I recall you get quite a bit of detail from that in the logs (under HA’s developer logs) though when I used it I was looking at the sensors not at the initial connections.
Another technique to see if the port is open, though it depends on how you have HA installed, is ssh into HA and see if the port is open to the system running BI:
ferguson@ha:~$ telnet 192.168.130.93 81
Trying 192.168.130.93...
Connected to watch.leferguson.com.
Escape character is '^]'.
Now show of trying to fake some http commands you cannot DO anything at that point but exit with the escape command and quit, but if you can’t get a successful connection you might get a clue why from the error. Make sure the TCP path to the port is clear of any filtering, routinging issues, etc.
Oh… use IP for BI not DNS names inside of HA. They broke a lot of names with HA (not BI) in a release a few months back by trying to “help” with local dns caching, to me DNS names no longer work reliably inside of HA.
