any idea? i delete all of HACS but still, I got on the log ERROR (MainThread) [homeassistant.setup] Setup failed for hacs: Integration not found.
No file under .storage or under configuration.yaml
also, I got this every time.
did you remove the integration from the configuration/integration page?
You have deleted it here ?
i dont have i this screen, my is like I add up, I try to back all the file and re try to remove it, still same issue.
There are instructions on how to remove HACS properly on the HACS website hacs.xyz
i just update with 115 and all work fine tx guys.
