HACS custom card install/uninstall never finishes
Some HACS custom card do not install or deinstall. The menu stays forever with the turning circle. What can I do to fix this?
uninstall forever
Open an issue on the GitHub repo for the card?
Unfortunately i have the same issue with HACS, only a very few cards install properly many other just takes forever loading.
@OP: Did you open a Bug Report on Github? If so please point me towards it, so i can add my comments
thx
I had the same issue
I turned out, that my problem was, that I used yaml mode Dashboards as well as UI created Dashboard
If you use both ways, HACS has a problem
@PX80 sorry, no, I didn’t file a bug report. I dropped my HA installation to start fresh. On the new one it didn’t appear again. But as @deluxestyle mentions, I also had mixed dashboards, yaml & UI created. I’ll keep watching it and if it appears again I might be able to pinpoint the reason better.
i wonder if someone can enable debug loggin. i mean it cant be that hard to simply download from github via HACS
I have the same problem. It only affects some cards. I’ve tried installing the affected cards later and always the same problem.
Here it was said that it is a network error:
https://github.com/hacs/integration/issues/3052
If so, what can I do?
I am currently using Win10 PC with WiFi.
