I am the Developer of the custom integration Keba KeEnergy. With this integration you can control heat pumps with an Keba KeEnergy control panel.
I wrote it for my heat pump from M-TEC but it must work for heat pumps from other manufacturers with a Keba KeEnergy control panel. The only requirment is that the Web GUI is enabled.
Hi Michael, nice job!.
I have a heatpump called Qbooster, (an other name here in Holland for tje M-TEC.
What I’m missing is a button to restart the system. Sometimes I have issue’s with a valve wehn I restart the system the issue is solved,
In a few weeks the valve will be replaced
Hi All
I’m considering to buy a M-TEC Heatpump. I have two questions I wasn’t able to find out using the search:
Is it possible to set the heatpump to cooling mode as well as adjust the target temperature for the cooling?
I learned the heatpump is able to modulate in a way, it only uses the unused power from the pv. Is it possible to use home assistant to provide the information of home much unused power is available to the heatpump? This way I wouldn’t have to install another power meter…
