HACS deleted my custom_components directory
This morning, I saw there was a update for HACS. Since I had been getting errors in my log about ‘Ophaalkalender repository being archived’, I removed the component and I updated Hacs. Result : config/custom_components directory removed. Same on my other HA instance.
Hopefully you had a good backup. :grimacing:
I just saw that there is a new update for HACS. Are you saying I should wait on doing that update? Which version were you on and which did you update to?
Just as a data point, I updated HACS to 0.24.2 this morning (pretty sure it was from 0.24.0) and it’s working fine - in fact, it cleaned up my custom components directory of old things that weren’t being used anymore, as well as removing the log errors about “xxx repository being archived”.
I don’t think it was the upgrade that was the cause, but the uninstall of the componont with the ‘repository being archived’. I just copied over my custom_components folder from one HA instance to the other, so no harm really done, since both instances run the same custom components.
Same happened here!
To me too :frowning:
Francis…sorry about the offtopic. I can’t reply on the other topic because it says I reached the reply limit for begginers. I edited a message there. Could you take a look please?
Francisp, thanks for your help on the other topic. I edited my message again. Begginers should be able to reply more than 3 times, since we need more help. When you have some time, please help me there. Thank you so much for your time and patience.
I’m having the same issue. I tried everything.
Sometimes is when I restart, other when I update.
I have a consistent message that HACS is outdated. When I try to update it, it takes for ever and eventually I get out of the pop-up and nothing, no message, no entry in logs.
Driving me a little crazy :slight_smile:
Overall everything works, I can install and update stuff in HACS, but HACS itself gets deleted from the custom_components folder. if I restore it everything works fine again.
