Hello
I’m having troubles with HACS and I’m very close to giving up on it.
I run hassOS on rpi4 and HACS was working fine until I updated Home assistant to 2021.4.3 few days ago (I updated since then and I’m on 2021.4.6 now).
Since then HACS cannot start. I reinstalled hassOS but still cannot install HACS. It complains it cannot access pypi to download and install
the latest hacs frontend package.
I tried opening an issue on the HACS github page but it was closed, saying those are network problems on my end (although I can download other addons, and ping pypi from within my hassOS, so the network seems to be ok).
So, as I see it there are two last things I can do. Those are my questions:
I would like to get to the OS shell and try installing those packages myself and see if I can fix it. But it seems that when I use a terminal addon
it seems i’m in the wrong container. I see the config directory but I cannot run pip install or pip update. How can I connect and manually run the pip commands ? -
If 1 is not possible, how can I manually install addons/integrations that are normally installed by HACS (If I download the source code from their git page) ?
Thank you
Guy
