HACS "Failed to setup"
I am having problems with HACS that appeared yesterday. It came from nowhere. No update of HA, no new sensors, no new integrations… nothing. It just stopped working. It is not visible in the sidebar either.
It starts to work after a while and then fails again. I have tried to remove HACS and reinstalled, which worked for a while. I have, after this appeared, also updated core and OS, but nothing helps.
I only have one integration related to HACS, which is Nordpool and it still works, but all cards are failing.
Anyone know wat is wrong? I canot find any solutions that helps when googling.
Did you find any solution to your problem? I am experiencing the same problem and I have tried to delete and reinstall but without success.
Thanks!
/Emil
