Core 2024.4.2
Supervisor 2024.04.0
Operating System 12.1
Frontend 20240404.1
I keep getting this error “HACS Failed to setup”.
In the Home Assistant Core Log:
Logger: homeassistant.config_entries
Source: config_entries.py:551
First occurred: April 8, 2024 at 8:56:08 PM (3 occurrences)
Last logged: 9:11:30 AM
Error setting up entry for hacs
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/hacs/__init__.py", line 220, in async_setup_entry
setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
File "/config/custom_components/hacs/__init__.py", line 206, in async_initialize_integration
await async_try_startup()
File "/config/custom_components/hacs/__init__.py", line 193, in async_try_startup
startup_result = await async_startup()
File "/config/custom_components/hacs/__init__.py", line 171, in async_startup
hass.config_entries.async_setup_platforms(
AttributeError: 'ConfigEntries' object has no attribute 'async_setup_platforms'. Did you mean: 'async_unload_platforms'?
What could cause this issue?
Thanks.
