HACS failure - music-assistant/hass-music-assistant
Not sure how long ago this started happening, but HACS isn’t working and shows “Failed to set up”
Looking at the logs I can see some errors with a couple other devices, but this seems to be the only stuff HACS related.
2025-01-07 15:27:25.216 ERROR (MainThread) [custom_components.hacs] HACS is disabled - restore
2025-01-07 15:40:42.899 CRITICAL (MainThread) [custom_components.hacs] [The repo id for music-assistant/hass-music-assistant is already set to 911125621] Restore Failed!
File “/config/custom_components/hacs/utils/data.py”, line 222, in restore
self.async_restore_repository(entry, repo_data)
File “/config/custom_components/hacs/utils/data.py”, line 270, in async_restore_repository
self.hacs.repositories.set_repository_id(repository, entry)
File “/config/custom_components/hacs/base.py”, line 290, in set_repository_id
raise ValueError(
…<2 lines>…
ValueError: The repo id for music-assistant/hass-music-assistant is already set to 911125621
2025-01-07 15:40:42.902 ERROR (MainThread) [custom_components.hacs] HACS is disabled - restore
2025-01-07 15:42:25.269 CRITICAL (MainThread) [custom_components.hacs] [The repo id for music-assistant/hass-music-assistant is already set to 911125621] Restore Failed!
raise ValueError(
…<2 lines>…
2025-01-07 15:42:25.271 ERROR (MainThread) [custom_components.hacs] HACS is disabled - restore
I believe they archived the MA in HACS over the last few days. The GitHub repo is no longer accessible. I don’t believe you can install it via HACS any longer. Even with a custom repository, the information just is no longer there.
They really shouldn’t have moved to core when they did while the voice functionality was not equal to the HACS version. Puts MA in a strange spot just when HA releases voice hardware for what I believe is the most significant use case for voice.
Ah ok, I didn’t realize.
Is there a way for me to fix this?
Check the github repo for hacs. I believe they updated hacs to resolve this. Otherwise there is a issues post on what to remive to get it working again.
I have a Yellow and installed an NVMe drive. The instructions say to stop HA, restore the file from backup, then restart.
Is there a way to stop HA but still have SSH access to the Yellow?
As for me, when I encountered such a problem, I removed the corresponding entries, that I have found in config/.storage/hacs.data and config/.storage/hacs.repositories.
(Mainly because I did not have a backup of hass config that could be restored as in solution)
Obviously, they were duplicated, and one of them was extra and should be removed, but, because, I did not use these, I opted to remove both.
Just make sure that you remove the entire JSON object (block that starts with "...": { or { and ends with },, take care to do not remove extra stuff) that you find when looking for music-assistant/hass-music-assistant in these two files, not just a single line.
Such manipulation helped for me to start HACS back.
But if you are not sure about JSON editing skills better make a backup first.
Afterwards, you will be able to update HACS to 2.0.2 using UI, which I suggest to do right away, so that it would not happen again.
is it a good idea to just remove/uninstall HACS and then install it again ?
can it be a solution for the problem described above ?
I just removed music assistant. That didn solve the problem. After that I uninstalled HACS and reinstalled it. That worked and also previous HACS integrations work again flawlessly without the need for any changes. Few!
What a beautiful design for the whole HACS component to fail because one of the packages was removed. It is as beautiful as everything in Home Assistant ecosystem.
This worked for me - thanks.
Yes the work around works but this is pain when you loose your UI :frowning:
Problem of test before releasing?
Thanks for sharing this. It worked me as well.
Had the same problem, it seems like an repo update added the new depricated repo without removing the old one first creating a big boo boo.
I finally fixed this myself. Full instructions. Migrating from the HACS Integration to the HA Integration · music-assistant · Discussion #3259 · GitHub
word. If you update, things break and you have to debug for hours. If you don’t update, things break and you have to debug for hours. I was really excited about the smart home future, but now not so much anymore.
so had to update to get the zendure hacs. Everything broke again. First sensorpush was double, so I hade to delete it with vi. Now adtpulse is double… if I have to go through 10 of these I will lose my mind.
water-heater-card
now I have this:
Logger: homeassistant.config_entries
Source: config_entries.py:749
First occurred: 8:54:20 PM (1 occurrence)
Last logged: 8:54:20 PM
Error setting up entry for hacs
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 749, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/hacs/__init__.py", line 246, in async_setup_entry
    setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
  File "/config/custom_components/hacs/__init__.py", line 214, in async_initialize_integration
    await async_try_startup()
  File "/config/custom_components/hacs/__init__.py", line 201, in async_try_startup
    startup_result = await async_startup()
  File "/config/custom_components/hacs/__init__.py", line 170, in async_startup
    async_register_frontend(hass, hacs)
  File "/config/custom_components/hacs/frontend.py", line 49, in async_register_frontend
    hass.http.register_static_path(
        f"{URL_BASE}/frontend", experimental_locate_dir(), cache_headers=False
  File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 512, in register_static_path
    frame.report_usage(
        "calls hass.http.register_static_path which "
    ...<7 lines>...
        breaks_in_ha_version="2025.7",
  File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 204, in report_usage
    _report_usage_partial()
  File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 251, in _report_usage
    _report_usage_integration_frame(
        hass,
    ...<4 lines>...
        integration_behavior is ReportBehavior.ERROR,
  File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 351, in _report_usage_integration_frame
    raise RuntimeError(
    ...<5 lines>...
RuntimeError: Detected that custom integration 'hacs' calls hass.http.register_static_path which does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles/frontend", "/config/custom_components/hacs/hacs_frontend_experimental", False)])` at custom_components/hacs/frontend.py, line 49: hass.http.register_static_path(. Please create a bug report at https://github.com/hacs/integration/issues`
Thanks. another :+1: from me. I used a couple of sed commands, but busybox sed is very minimal.
