Go tot the HACS page in your browser. Open the console and disable the cache. Then hold ctrl + shift and press r
Firefox version 85.0.2 64bit
Thatās the very first thing I tried I had to do it 5-6 times for the message to disappear, that is weird.
I am using Cloudflare DNS with an nginx proxy on my end. Had to log into Cloudflare and clear cache from there to solve the issue.
Thanks Mikefila,
That worked for me in Chrome, as well.
If you are using Nginx Proxy Manager as the reverse proxy for Home Assistant, Check the Proxy Host settings for Home Assistant and make sure Cache Assets is unchecked. Uncheck it if needed then clear browser cache and hard reload and should be fixed.
I just had this issues, too. There is an easy and fast way to fix it.
I hope, I could help a little bit.
Perfect, thanks.
This solved it for me. Thanks!
