I have tried going to https://get.hacs.xyz and copy and pasting the code into terminal, with no luck.
I researched on this forum and someone said to turn off ‘Protection mode’ on the Advanced SSH & Web Terminal. I tried that and relaunch HA and ran the script, but with no luck.
I’m not sure what else to do, if anyone has any advice. Thanks
Did you try the alternative url? wget -O - https://raw.githubusercontent.com/hacs/get/main/get | bash -
Also try to follow this: Download | HACS
While youtube can be handy for guides they tend to be outdated quickly regarding HA.
The official guides / githubs are usually more up to date.
Agreed. I run an HA-centric YouTube channel, and as a general rule, any videos older than ~6 months should only be taken for theoretical/inspiration value, not literal “type this exact thing or click these exact buttons” type instruction.
Things change WAY too fast with this platform.
So yeah, OP - if there’s a YouTube creator that you like, subscribe to them and follow them and watch the videos right when they come out, because looking for the info a year down the road isn’t likely to do you much good.
Because of this, I’ve already covered the same topic multiple times, to make sure I provide current, relevant info. It’s a constant struggle. LOL
