HACS install - stuck
I put hacs in where I think it should be:
~/docker/homeassistant$ ls
automations.yaml  configuration.yaml  custom_components  deps  groups.yaml  home-assistant_v2.db  scenes.yaml  scripts.yaml  secrets.yaml  tts
~/docker/homeassistant$ ls custom_components/
hacs
I restarted (both with the UI and restarting the docker container)
The UI doesn’t list the integration, so I added it to configuration by hand.
but get:
"Setup failed for hacs: Integration not found."
Same here. Checked everything I could, all files are there, HA version 0.111.1 and latest hacs.
