I did not update HA for quite a while. Now I did, as well as all plugins, components and so on.
I also installed the most current version of HACS and it is running fine, also updating components. But it seem that HA isn’t loading those components (located in config/www/community) any more. I.e. mini-graph-card and mini-media-player.
Was there a change in the last versions, how those components have to be placed or something? However I read the latest HACS install guide and found nothing that might be missing in my installation…
You need to be more specific about which version you updated from. There have been many changes that could be affecting you.
The most likely one however is that resources for custom cards are no longer located in the Lovelace config (raw file or yaml). Look in the Configuration / Lovelace / Resources menu.
All the resources should now use the /hacsfile/ location and type should be module.
This awesome new feature comes with a deprecation if you use Lovelace in manual YAML mode: You need to move the resources section from your ui-lovelace.yaml to the lovelace: section in configuration.yaml . It is not a breaking change yet; we still load them from the previous location if we didn’t find anything in the lovelace: section, however, this fallback is being removed in a future version.
If you manage your Lovelace via the frontend, we automatically migrate your resources. Please note that resources are not in the raw Lovelace configuration editor anymore, but in the Lovelace configuration panel.
You really should read all the breaking changes before updating.
Okay, I got it working again. I moved the resources over to the config yaml, however I think it was more important to change the paths of the plugins to the new /hacfiles/
I updated from Hassio 0.8 and am figuring out all the changes.
I just learned about HACS and installed it a few days ago.
However, it’s not working…I see it in the hassio sidebar, can download plugins, but those elements do not seem to be activated / usable in the frontend
I do have a www/community folder with the plugins
Can you tell me exactly what solution you applied so I can see if that is my solution too?
Did you move the community files to hacfiles ?
Or listed the www/community/ directory somewhere?
I don’t remember exactly what was going on, as it was some time ago. However, reading my posts I think you could try to move your stuff to the hacfiles directory and see if it works after a restart
You can easily change it back if you have no success or it becomes worse.
