Is it possible to force an hacs integration (ex. bambu lab) to be in english. I use a french language homeassistant. I want the entities create by the hacs integration to be in english
I want to use the wolfwithsword dashboard ( Bambulab Home Assistant Dashboards ) but it require that bambulab entities are named in english.
What you can try to test out is to remove the translations (all but en.json) from the custom app folder and then restart. With every update of the custom app those will return though
Hi there! If the previous solution doesn’t work or becomes annoying to do after each update, you can instead find the names of sensors inside each YAML from the dashboards and manually do a replace-all, and then they will work as expected.
