HACS integration issue
I have an issue when I try to include HACS into my RPI4. It used to work before updating to 0.104.3, but now every time I click integration -> HACS it goes back to the list of integrations. The HACS team says it is an issue with homeassistant, but I honestly don’t know what to do to fix it.
Below is the error log. HACS team says it happens before HACS is even called. Everything else works, except HACS and I don’t want to have to start over at this point.
2020-01-26 16:00:00 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 127, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 50, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 59, in post
    handler, context={"source": config_entries.SOURCE_USER}
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 100, in async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 500, in async_create_flow
    await async_process_deps_reqs(self.hass, self._hass_config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 290, in async_process_deps_reqs
    hass, integration.domain
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 55, in async_get_integration_with_requirements
    hass, integration.domain, integration.requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in async_process_requirements
    if pkg_util.is_installed(req):
  File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
    return version(req.project_name) in req
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3138, in __contains__
    return self.specifier.contains(item, prereleases=True)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
    item = parse(item)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
    return Version(version)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
    match = self._regex.search(version)
TypeError: expected string or bytes-like object
If all you did was update to 0.104.3 you don’t have to do anything. HACS should still be there.
