Hi
I have a HA instance up and running including HACS Integration (with a valid Github Token)
I started to work on the setting of a Proxmox HA Based new system. Everything is configured and working fine.
I would like now to add HACS on that 2nd HA Instance. As I already have a token created and used on my 1st HA Instance, I was thinking to use the same here for my 2nd HA Instance ==> Unfortunately when I created that original 1st Token for my first HA Instance, I didn’t write it anyware (so I don"t remind it and didn’t find how to see it again under Github and under HA too).
Note: : I’m using UI integration for HACS and not YAML Config
I could create a 2nd Github Token for sure in GitHub, but is there a way to use my 1st token in my 2nd HA Instance ? Any idea how to proceed ?
