I cannot install HACS integration.
After HASSIO restart, im going to integrations/HACS but nothing happens.
In logs I Have got:
Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 40, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 136, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 130, in post
return await super().post(request)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 48, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 60, in post
handler, context={"source": config_entries.SOURCE_USER}
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 66, in async_init
flow = await self._async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 638, in _async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 292, in async_process_deps_reqs
hass, integration.domain
File "/usr/src/homeassistant/homeassistant/requirements.py", line 51, in async_get_integration_with_requirements
hass, integration.domain, integration.requirements
File "/usr/src/homeassistant/homeassistant/requirements.py", line 87, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/src/homeassistant/homeassistant/util/package.py", line 45, in is_installed
return version(req.project_name) in req
File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3138, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
Other integrations works fine.
