I am running HA Core in a docker. I recently got HACS integrated but when I download an integration they are not accessible in HA. I see them in the Customs folder but they do not appear to where I can use them. Do I need to add them to the configurations.yaml file?
HA needs to be restarted if you have not done so.
I have restarted it many times and cleared cache.
The answer seems to be: “it depends”, some HACS installations require follow-up via configuration.yaml. Others can go through config>integrations and search for them … usually the documentation with the HACS packages describe what to do next…do you have an example maybe?
