There is an update showing up for HACS so I clicked and after it is done HACS and everything inside HACS are all gone!!
Log shows:
CRITICAL (SyncWorker_18) [hacs] You need HA version 0.110.0 or newer to use this integration.
I’m on 0.109.2, are there any breaking change to upgrade HA to 0.110.0? if not how can I get HACS back?
Thanks!
yes, the latest hacs needs 110
so you need to upgrade HA or rollback hacs, which is presume you’ll have to do manually
Thanks.
It would be great to prevent HACS to upgrade if newest version is not compatible with current HA version.
Yep mine too!! Just done this 5 mins ago and has broken all sonoff/tuya connections. No hacs and cannot seem to fix it.
Going to try a snapshot I did a few days ago
I’m on 0.109.2, didn’t see something like this when I click upgrade ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=9)
I had 0.110.0 (may have been 0.110.1) still broke everything
hmm snapshot is taking ages…
SaNewm
(Samuel Newman)
8
To be fair it was right there in the release notes.
I’m back online. It was the Home assistant Core I updated not HACS my bad! But still…
Hacs has 1.0.2 available (I’m on 1.0.1)
Home assistant core available 0.110.2 (Current 0.110.0)
So should i update HACS first this time? I need to read those long release notes
Luckily I had a snapshot from yesterday
The weather card options on the new HACS have gone. I’ve only got darksky listed and looks like I need to pay for that.
All ok now with both upgrades.
Core: version 0.110.2
HACS: 1.0.2
One learning experience after using a snapshot. Corrupts your native DB.
Had to delete it and restart.
Documentation says 0.98 or newer… I was played!
