Hi!
today I updated my HomeAssistant from 2021.4.4 to 2021.4.6 version and now i have some problems with HACS.
HACS is running, but this message appears:
"HACS is starting.
HACS is starting up, during this period some information may be missing or incorrect "
If I try to update a component of HACS, when I restart HomeAssistant it returns as before updating it.
When I restart HomeAssistant, I get the following errors:
Logger: homeassistant
Source: custom_components/hacs/hacsbase/hacs.py:195
First occurred: 18:12:01 (1 occurrences)
Last logged: 18:12:01
Error doing job: Task exception was never retrieved
File "/config/custom_components/hacs/hacsbase/hacs.py", line 140, in startup_tasks
await self.handle_critical_repositories()
File "/config/custom_components/hacs/hacsbase/hacs.py", line 195, in handle_critical_repositories
critical = json.loads(critical.content)
AttributeError: 'list' object has no attribute 'content'
Logger: custom_components.hacs
Source: custom_components/hacs/repositories/integration.py:64
Integration: HACS (documentation, issues)
First occurred: 18:11:50 (1 occurrences)
Last logged: 18:11:50
<Integration hacs/integration> Could not read manifest.json [encoding without a string argument]
I tried to delete the integration and do it again, but I didn’t fix the problem
please have you any solutions? Thanks
