Hacs issue user interface
After HACS installation the friendly user interface (integration/ frontend etc. ) does not show. I only see the list view and I need to search and find integration through a list view.
I reinstall HACS couple of time and delete the cache.
what can be cause of this problem.
You must have ticked “experimental features” when installing. This is what HACS 2.0 will look like.
There is a drop down filter (click on the inverted pyramid, top right) which allows you to focus lists and searches.
If you search the forum, you’ll see several other topics where it is explained that this is when experimental features are enabled in the configuration. So turning it off and restarting should show you the old interface.
But at some point the list view will be the default, non experimental and only option I imagine, so you could also get used to it as I did. I do not agree that it is not user friendly. The options to filter what you want to see are nice and you can find stuff very quickly.
I have 16 HACS integrations, but it is not like I use it on a daily basis anyhow. Once you have the integration you need there’s rarely any need to go there.
