Was having a issue with the scheduler card so decided to uninstall and reinstall
I did the uninstall but now the addon is no longer listed in the cards.
How can I re add this so i can reinstall.
I also tried another random card and also once uninstalled it is no longer available to reinstall
tom_l
October 2, 2021, 5:12am
2
HACS has never supported addons.
There are a number of scheduler integrations and cards . Which one were you using?
Have you tried searching for the github repository and reading the installation instructions?
The card may require a custom repository to be added or an integration to be installed first.
Sorry bad use of words. It is an custom card not an add-on
If I try to readd the repository hacs says it is already in the store.
It was but a search no longer shows it to reinstall
It is as if I have hidden it but canât find a way to show hidden items.
tom_l
October 2, 2021, 6:34am
4
Make sure you are searching in the Frontend section of HACS, not the Integrations section.
finity
October 2, 2021, 1:24pm
6
you also might try a cache reload (ctrl-F5 in chrome)
Are you searching in the right place? Make sure youâre not using the âSearch for installed or new repositoriesâ search bar at the top, but go via the "+ EXPLORE & ADD REPOSITORIESâ button at the bottom right, and then use the search bar in the pop-up.
Step 1:
Step 2:
[Thought it would be worth checking as this has caught me out in the past]
