HACS not working after recent updates 'failed to setup'
HACS has been showing the error for a few months now but I can’t seem to get it to clear.
I’m using the yaml installation method. It has been working for months all fine but suddenly the error has occurred.
I’m using the latest update of HACS, which shows no errors on the homepage, only within the integration page of HA. The associated integrations all stll work.
I’ve changed the access token from Github. I’ve not uninstalled it as of yet, as I’ve read about people having issued going down that route. Any suggestions?
You shouldn’t set it up in YAML and in the UI, and that’s what you’ve done. Pick one, and I recommend removing the YAML config and just setting it up in the UI with OAUTH authentication rather than bothering with the token.
