I am trying to use some items from Hacs how ever im unsure on a few things.
I am unsure what they mean by the info below.
"When installed, this will be located in ‘/config/www/community/surveillance-card’, you still need to add it to your lovelace configuration (‘ui-lovelace.yaml’ or the raw UI config editor).
It’s funny, I was looking for documentation for you but I can’t find any about this topic ‘getting started with Lovelace’. You don’t have to use lovelace.yaml, that is the advanced configuration option. For starters, you can start editing lovelace through the UI.
I believe the Lovelace ui can be activated on the About page (same page where your log is). After activating, you can click the three-dots-menu in the upper right corner and click Configure UI. That’s a start.
Not in configuration.yaml. After you clicked Configure UI, the same menu contains a link to Edit Raw configuration. There in the resources section you paste the lines you mention. Save then Ctrl-F5 for refresh.
Okay. I have a general question… when im in my configuration.yaml file and lets say i want to add the speedtestnet sensor do I add it in under sensors ?
so like this
sensors
platform: speedtestdotnet
or do i set it up this way
