Hi, any solution for this so far?
I have aswell two instances of HA runnning. Both have HACS 1.33.0 installed, but the Frontend Version (in the "“about” section) in the way older instance is 20220906112053 and shows the short list with the Themes/Integrations/… sections. The other instance has frontend 20230406083157 and shows the same list as in your screenshot.
I reinstalled HACS, removed it completely etc. on the instance with the 2022-Frontend. But i never managed to get the frontend of HACS updated.
The logs do not show any error or other strange things.
I have no issue learning and start using the new interface - as i tryed literally everything suggested above and below - but how can i add a repo which is not in the repo list? so if i type for example “Inels” in the search bar, or at the menu - it does not find the InelsforHAAS repo…
Have the same problem, although I don’t mind the new interface, what I see is that some custom-card that are downloaded do NOT show up when I edit the dashboard and want to use them (some other custo-card do appear).
Same happened to me, integration, frontend, add-ons and about not showing even after ckear cache and restart (im using chrome on mac).
It work for me when I try open in safari.
Try use different browser. Maybe the cache not completely cleared.
Hello, I just get the new home assistant green and follow the steps to install the hacs but when I copy & past it on terminal & ssh I get a message saying : No such file or directory.
Can you help me please?
Same happened to me, integration, frontend, add-ons and about not showing even after clearing cache and restart chrome and edge on PC
This is not availabe any more “Go to Settings / Devices & Services / Integrations click on the HACS integration ‘Configure’ button and uncheck ’ Enable experimental features’ This will return your page to the way it was before the update.”
