HACS question about adding repositories
Maybe… I add them as this url:
eg
https://github.com/thomasloven/lovelace-toggle-lock-entity-row
so maybe your shorthand isn’t working? I don’t use this card so speculation.
pasting thomasloven/lovelace-toggle-lock-entity-row and selecting plugin worked in my test
The shorthand worked in other cases, but not this one (and some others)…
Shall I raise an issue?
2019-06-15 09:13:29 [custom_components.hacs.frontend] GET POST call for repository_register with new
2019-06-15 09:13:29 [custom_components.hacs.frontend] GET POST call for thomasloven/lovelace-toggle-lock-entity-row  with plugin
2019-06-15 09:13:29 [custom_components.hacs.hacs] Starting repository registration for thomasloven/lovelace-toggle-lock-entity-row
2019-06-15 09:13:29 [custom_components.hacs.hacs] thomasloven/lovelace-toggle-lock-entity-row  - Not Found
2019-06-15 09:13:29 [custom_components.hacs.hacs] thomasloven/lovelace-toggle-lock-entity-row  - Could not register.
2019-06-15 09:14:55 [custom_components.hacs.frontend] GET API call for log with get
Can you create a issue for it? That should have worked…
Done - let me know if you need anything else
I just installed HACS on Hass.io and am now trying to add my icloud3 repository to it on the Settings page as a custom repository. I will be submit it to the store as store when I get a handle on how it works.
The repository is gcobb321/icloud3.
The device_tracker.py file is in icloud3/custom_components directory.
I have tried all kinds of file name combinations and can not get it to find the device_tracker.py file and an not figure out how it should be added. I’ve tried…
gcobb321/icloud3
gcobb321/icloud3/device_tracker.py
gcobb321/icloud3/custom_components/device_tracker.py
gcobb321/icloud3/custom_components/icloud3/device_tracker.py
gcobb321/custom_components/icloud3/device_tracker.py
Changed the directory structure to custom_components/icloud3 and tried:
gcobb321/icloud (it starts scanning but still can not find anything)
The file type I’ve used in Integration since it is a custom component.
Every combination resulted in File Not Found error and Could Not Register message
Any help would be appreciated.
https://github.com/ludeeus/icloud3/commit/6e400d4888a3c1b879d2ad5101b3609c9f84d2fb
https://github.com/ludeeus/icloud3/tree/master/custom_components/icloud3
is correct.
The reason it did not work when you tested:
https://custom-components.github.io/hacs/developer/integration/#github-releases-optional
https://github.com/gcobb321/icloud3/tree/v1.0.5/custom_components-icloud3
How do you add card-tools repository?
