Hacs Reolink ip Camera vs Home assistant Reolink IP NVR/camera
Hi all I have been using the HACS Reolink integration with my RCL 420 Cams for sometime,
I use Doods 2 , and Node-red so when a person is detected it triggers HA to record the Camera, using the Sub video. this work well but I would like a higher video resolution.
So I tried the HA Reolink IP NVR/camera integration with this I can feed Doods the Sub Video and get the Main Video feed to record, But I am missing about the 1st 20 seconds of video compared with the HACS integration even if I set the recording to the Sub video. I am still missing the 1st 20 seconds,
looking at my video from the HACs intergation it looks like Im getting a lookback before the camera starts to record. I have put the lookback argument into the node for the recording in Node-red and it makes no differences,
Anyone have any ideas?
Found the issues I had to set the camera to live view
Glad you figured out the issue!
Any other problems with the build in reolink integration?
If you appreciate the reolink integration and want to support its development, please consider sponsering the upstream library or purchase Reolink products through this affiliate link.
no not at all worked 1st time
