I have setup supervisor on a Raspberry Pi 4 4GB Bullseye 64bit (core-2022.2.6, supervisor-2022.01.1 stable). I have loaded HACS, and downloaded the SolarEdge Modbus TCP repository via HACS. The logs tell me… 2022-02-17 15:14:23 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration solaredge_modbus which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Everything appears to be running and stable at this point, however… I can see the integration in HACS, but I see no sign of it anywhere else. I have tried to add an integration in configuration/devices & services/add integration, and it does not show there. I have tried looking in the community add-ons in the add-on store and it does not show up there either. I am new to HA and the documentation in the repository is not really clear on this matter. It tells me “Go to the integrations page in your configuration and click on new integration → SolarEdge Modbus”.
What am I overlooking / doing wrong?
Thank You in advance,
Anthony Todd
