Hi there,
I’m running HA 0.108.9 on Synology Docker and have HACS installed. But after a reboot it seems, that HACS is running for the first time although it was initialized before.
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 216, in async_setup
hass, self
File "/config/custom_components/hacs/__init__.py", line 85, in async_setup_entry
startup_result = await hacs_startup()
File "/config/custom_components/hacs/__init__.py", line 164, in hacs_startup
await setup_frontend()
File "/config/custom_components/hacs/setup.py", line 103, in setup_frontend
require_admin=True,
File "/usr/src/homeassistant/homeassistant/components/frontend/__init__.py", line 190, in async_register_built_in_panel
raise ValueError(f"Overwriting panel {panel.frontend_url_path}")
ValueError: Overwriting panel hacs
Any suggestions…?
Thanks,
Oliver
