Hello
I just updated my hassos to 2021.4.3 and HACS (that was running just fine before) stopped working.
The log says:
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”)’: /simple/hacs-frontend/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”)’: /simple/hacs-frontend/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”)’: /simple/hacs-frontend/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”)’: /simple/hacs-frontend/
ERROR: Could not find a version that satisfies the requirement hacs_frontend==20210214110032 (from versions: 202006281222, 202007180957, 202008050145, 202008231558, 202009091732, 202009242003, 202011142129, 202011151903, 202011221222, 202012051441, 202017310251, 20201205162459, 20201223145936, 20210102161751, 20210103144316, 20210131153018, 20210207162610, 20210213120600, 20210214181913)
ERROR: No matching distribution found for hacs_frontend==20210214110032
WARNING: You are using pip version 20.2.4; however, version 20.3 is available.
You should consider upgrading via the ‘/usr/local/bin/python3 -m pip install --upgrade pip’ command.
2021-04-13 06:54:04 ERROR (MainThread) [homeassistant.setup] Setup failed for hacs: Requirements for hacs not found: [‘hacs_frontend==20210214110032’].
It seems like it cannot access pypi to download the necessary python libs.
Has anyone experience such behavior ? Is there a known solution ?
Thank you
Guy
