HACS stuck on old version
I updated to the newest HAOS, but HACS is still stuck on version 1.13.2.
Updating and restarting does not change anything. Here are suspicious errors:
 Logger: custom_components.hacs
Source: custom_components/hacs/helpers/functions/get_list_from_default.py:24
Integration: HACS (documentation, issues)
First occurred: 12:05:50 (4 occurrences)
Last logged: 12:05:51
    GitHub returned HttpStatusCode.NOT_FOUND for https://api.github.com/repos/hacs/default/contents/HacsCategory.REMOVED
    GitHub returned HttpStatusCode.NOT_FOUND for https://api.github.com/repos/hacs/default/contents/HacsCategory.INTEGRATION
    GitHub returned HttpStatusCode.NOT_FOUND for https://api.github.com/repos/hacs/default/contents/HacsCategory.THEME
    GitHub returned HttpStatusCode.NOT_FOUND for https://api.github.com/repos/hacs/default/contents/HacsCategory.PLUGIN
You need to go back like 3 years with you home assistant version for that to work.
This is a byproduct of ignoring updates for too long.
You now have 2 realistic options:
  1. Just remove HACS from you system, it’s clearly not used.
  2. Follow the download instructions from HACS documentation to “force” an “upgrade”.
Option 1 is probably best (and my own personal favorite in this scenario).
I used it to get Local Tuya and Apex Charts, but Local Tuya is also broken after the update and Apex Charts seems to work without HACS, so I removed HACS for now.
I wanted to try HACS again, but after re-installing it still gives version 1.13.2 again. The version somehow persists across uninstall and re-install for some reason.
Did the 3 times restart + folder deletion via samba: Remove | HACS + reinstall Download | HACS
Now Tuya 2 is no longer found by the new HACS, but Local Tuya works again, so I switched from Tuya 2 back to Local Tuya.
