It is in the directory where you used the wget -O hacs.sh https://get.hacs.xyz
command.
Use the console and type ls to list all files in that directory and edit the file like Joshi said
command.
for me also, thank you!
ist ja verrückt… funktioniert !
Same issue here, fresh install of HAOS on bare metal, trying to install HACS, and it just spins…
Is there a fix vs having to downgrade HA?
Thank you soooooooooooo much … it worked like magic for me … I wasted several hours for nothing … your solution was easy and effective
Vielen, vielen Dank - das zurücksetzen hat perfekt geklappt!
Wow. This worked for me! Thanks mate!
Thank you!! This worked for me
Where can I find the downloaded “hacs.sh” file? And how to reupload it?
find the line and replace it with
wget “https://github.com/hacs/integration/releases/latest/download/hacs.zip”
paste (right mouse button)
wget “https://github.com/hacs/integration/releases/download/1.33.0/hacs.zip”
Danke, hat geholfen.
Thank you, worked perfect with downgrade.
Chiming in to say this worked for me too, thanks very much! I’m using the container version of HA, so I had to
docker exec -it homeassistant bash
first to log into the container. If that helps anyone!
This works perfectly
I’m hitting this too.
Absolute beginner so all of the above might as well be another language.
I have Home Assistant set up in UTM on a Mac Mini.
Any help would be great.
Worked! Thanks
Try downgrade the hacs version, as Vinay told:
hacs.sh
” file with your preferred text editor.wget "https://github.com/hacs/integration/releases/download/1.33.0/hacs.zip"
bash hacs.sh"
That worked for me! Thank you!
kesin çözüm. teşekkür ederim
Created account to like this.
Worked for me! thank you!
