HACS stuck 'waiting for device activation'
I succeeded in activating the github integration, and il have this screen appearing :
I tried several times full new installations of HA and Hacs, and it is always the same … Can you help me ?
Thks…
PS; I have updated Hacs and HA to the last versions.
That helped me too. Thanks!
I’m experiencing the same issue. I installed HACS yesterday following the instructions on the official HACS website. Should I uninstall this version before following the instructions provided by @vinay01joshi ?
Great thanks! it works
How to edit “hacs.sh” file. Is the file somewhere in the directory?
This has been a wasted morning. I’ve tried several solutions mentioned in this thread w/o success. Have the authors of HACS addressed this issue?
Just done another Home Assistant update for May 06 version, (Backup and Update) - HACS loaded after that … maybe it could work for you now?
I finally got it loaded. I used the script hack to drop back a version for the install and did the update after.
No you can just follow the instruction .
use vi editor.
thanks
but I have a problem after starting the script via SSH on NAS
ERROR: 'unzip' is not installed
I am with HA Container on docker under DSM Synology…
EDIT: it’s OK. I opened a terminal in docker Home Assistant and got
homeassistant:/config# bash hacs.sh
INFO: Trying to find the correct directory...
INFO: Found Home Assistant configuration directory at '/config'
INFO: Changing to the custom_components directory...
INFO: Downloading HACS
Connecting to github.com (140.82.121.3:443)
Connecting to objects.githubusercontent.com (185.199.111.133:443)
saving to 'hacs.zip'
hacs.zip             100% |*********************************| 3910k  0:00:00 ETA
'hacs.zip' saved
WARN: HACS directory already exist, cleaning up...
INFO: Creating HACS directory...
INFO: Unpacking HACS...
INFO: Verifying versions
INFO: Current version is 2024.5.1, minimum version is 2023.6.0
INFO: Removing HACS zip file...
INFO: Installation complete.
INFO: Remember to restart Home Assistant before you configure it
Hi this was 100% doing my head in.
I signed up for my 1 month free trial of the cloud thing and presto it immediately worked at the next
Attempt. I tried downgrading, rebooting, clearing cavhes etc nothing worked. But the free trial did.
Hope this works for others.
Obviously one questions why!
Hi there,
I’m totally stuck with this issue. I spent hours and hours without success. I really need HACS to get some integrations that are very important to me.
I’m running HA in a VM on my TrueNAS.
Versions:
  • Core 2025.2.3
  • Supervisor 2025.02.0
  • Operating System 14.2
  • Frontend 20250210.0
  • HACS Installer 2.0.5
What I tried so far:
  • Downgraded HACS as mentioned by @vinay01joshi
  • Rollback of HA as mentioned by @KiiDii
  • Updated HA to the latest version
  • Restarted HA several times
  • Cleared browser cache
  • Logged off from all other devices
  • Created new GitHub account
  • Started GitHub Enterprise trial
  • Resent last POST entry
  • Edited last POST entry (inserted IP-address instead of hostname)
  • Disabled IPv6 in HA
  • Disabled IPv6 in my router
  • Tried different browser (firefox)
  • Tried different computer
I didn’t suceed in editing /homeassistant/cusom_components/hacs/config_flow.py as mentioned on GitHub custom_components.hacs.config_flow::HacsFlowHandler calls async_show_progress without passing a progress task · Issue #3649 · hacs/integration · GitHub
Isn’t the issue allready fixed?
Debuglog output:
2025-02-14 17:15:55.040 DEBUG (MainThread) [aiogithubapi] The authorization request is still pending.
2025-02-14 17:16:00.195 DEBUG (MainThread) [aiogithubapi] Too many requests have been made in the same timeframe.
2025-02-14 17:16:00.195 INFO (MainThread) [aiogithubapi] Got new interval instruction of 10 from the API
Please help me, I’m totally frustrated now…
Edit (2025-02-16): opened GitHub issue
HACS activation impossible: Too many requests have been made in the same timeframe. · Issue #4448 · hacs/integration
My GitHub issue was answered:
ludeeus
I do not think this is a HACS issue, but something with your host/network or GitHub account.
Can you try GitHub - Home Assistant?
If you have the same issue with the GitHub integration, it would confirm that.
spaxx2000
I tried to add the GitHub integration as you suggested and I can confirm that it has the same issue.
ludeeus
That is good, at least, but I have no idea as to why; I suggest seeking help on the Home Assistant discord server or Forum.
Closing this for now as this is out of HACS control.
I have the exact same issue for the last couple of days. Is there a fix or workaround for the 2025 version of this issue? Is it a github issue? Has anyone got past it?
I’m trying to add HACS integration to a new Home Assistant Green (Core: 2025.3.1; Supervisor 2025.03.2; OS 14.2; Frontend 20250306.0).
Any help or advise much appreciated.
Are you me? Let me know if find a resolution, this has been very frustrating… My HA-OS VM needs HACS so I can do things, as it’s hanging. I’m following your GH issue too.
Similarly, I cannot Integrate directly with the GitHub addon either.
Hey Kyle,
yes I am ‘Me’ :wink: I edited my post for clarification.
Good to know, I’m not the only one having the issue…
May I ask what is your underlying infrastructure? I’m on TrueNAS Core and running HAOS in a VM. Trying to rule out the reasons ludeeus mentioned (host/network or GitHub account)…
Hy, what 1 month free trial are you talking about ?
This one https://www.nabucasa.com/
thank you ! i did this and after i tried again, the activation was a success ! I have no idea why :slight_smile: But thank you !!!
