HACS unavailable for integration
I ran the command
wget -O - https://get.hacs.xyz | bash -
and can see the file structure from ssh. I restarted the Supervisor, and then rebooted, but HACS does not show in the ADD-STORE search.
all of those passed?
Prerequisites
Requirements
warning
If you do not have or know all of the following, do not try to setup/use HACS.
  • Home Assistant version 2021.9.0 or newer
  • A GitHub account
  • A supported Home Assistant installation
  • Access to the filesystem where Home Assistant is located
  • You know how to access the Home Assistant log file
  • A stable internet connection with sufficient available data or no data caps
RTFM!! It is an Integration, not an Addon
