HACS, YAML Mode, Frontend Cards and Resources, Reload without Restarting HA - HowTo
I edit the dashboard in YAML mode and whenever I add a new Frontend card via HACS, I thought I had to restart HA after adding the url and type within resources: in the configuration.yaml file.
Despite doing many searches to find an answer, either I wasn’t using the correct search terms (more likely) or there was no clear explanation as to how these resources could be loaded without a HA reboot.
A lot of you may already know how to do this, but for people like me who don’t, here is a guide that will show you how to install a frontend card without rebooting HA.
First of all, adding the following card yaml into ui-lovelace.yaml results in the expected error where the card can’t be found:
  - type: 'custom:bar-card'
    entities:
      - entity: sensor.plug_zigbee27_power
      - entity: sensor.plug_zigbee26_power
Next download/install the card via HACS
Here is where it tells you to manually add the resource url and type to configuration.yaml
Add this to the resources: section and save your configuration.yaml file
lovelace:
  mode: yaml
  resources:
    - url: /hacsfiles/button-card/button-card.js
      type: module
    - url: /hacsfiles/lovelace-layout-card/layout-card.js
      type: module
    - url: /hacsfiles/decluttering-card/decluttering-card.js
      type: module
    - url: /hacsfiles/simple-clock-card/simple-clock-card.js
      type: module
    - url: /hacsfiles/bar-card/bar-card.js
      type: module
You can see which resources have been loaded by navigating to Settings → Dashboards → 3-dot menu top-right → Resources
As seen below, I don’t yet have button-card listed.
Go back to your dashboards main page (Overview by default), and select the 3-dot menu top-right and then press Reload Resources
If you go back to the Resources page mentioned above, you will now see that button-card is listed!
However for me, back on the home dashboard page, clicking Refresh within the 3-dot menu still didn’t show the bar card…
The final step is a full browser refresh which can usually be accomplished by shift+left-click the refresh button on your browser:
This worked for me and saved having to reboot HA. Hope this helps others too.
Is there any way to reload resources without setting lovelace mode to yaml? Doing so deleted all of my views and now I’m restoring from a backup to get them back. Normally I only have the edit dashboard option in the three dot menu.
Also more importantly to anyone reading: SETTING LOVELACE IN YOUR CONFIG.YAML WILL DELETE YOUR DASHBOARD VIEWS AND REMOVING IT AND RESTARTING WILL NOT RESTORE THEM. You’ll have to restore from a backup.
I don’t think you need to reload resources to use new frontend cards in non-yaml mode because you don’t need to add them to configuration.yaml. I could be wrong though…
This was a super helpful guide. Thank you!
