HADashboard-activated scene, automation issue
Hi all,
I’ve just set up HADashboard and I’ve configured a dashboard where I can set some of my scenes. In HASS, I have some automations configured to execute when some of the scenes are set, for instance:
- id: arm_alarm_when_goodnight_scene_is_activated
  alias: Arm alarm when I go to sleep
    platform: event
    event_type: call_service
    event_data:
      domain: scene
      service: turn_on
      service_data:
        entity_id: scene.going_to_bed
    - service: alarm_control_panel.alarm_arm_home
        entity_id: alarm_control_panel.alarm_panel
When I activate the scene through the HASS UI, or through Homebridge, this works fine. However, when I activate it via HADashboard, it doesn’t fire, i.e. the scene is set, but the automation is not triggered.
Any clues?
Thank you
what do you have in your dashboard?
going_to_bed:
  widget_type: scene
  entity: scene.going_to_bed
  title: Going to bed
layout:
  - going_to_bed
i just checked and the scene widget uses the service homeassistant/turn_on instead off scene/turn_on
you could solve your problem by copiing the files scene.yaml i the widgets dir to the custom_widgets dir.
rename it to something like my_scene.yaml and use that in your widgets_type
in that yaml file change homeassistant/turn_on to scene/turn_on.
Thank you ReneTode for your suggestion. Actually, since it was just the trigger that was causing the issue, I’ve modified my automation to be triggered by both service domains (scene and homeassistant). It works fine now.
Thanks again
Do i need to create which dirs inside appdaemon folder to use the scenes.yaml?
that is about custom widgets.
you first need to learn about normal widgets.
