Hi just installed HADashboard and i have come across a problem with a sensor font.
The only thing i can see is that the sensor (Distance Home) is a template sensor.
And i can not get or see a way to add a camera onto the dashboard any help with this would be great.
On HADashboard, the Sensor Widget uses a different font if it detects text rather than a numeric value. You can override this using the various style arguments documented with the widget.
Regarding the camera - search the docs for the Camera widget!
Thanks the font worked
text_style: “color: $blue; font-size: 200%”
Still not sure how to get the camera into The dashboard. Can you give an example please.
in your appdeamon directory read the DASHBOARD.md
you also find examples there
Thanks Guys
Got it the cameras working.
