Hadashboard - modal dialog buttons - SOLVED
I know this isn’t technically a hass issue, but looking for some assistance if possible.
I am trying to implement hadashboard on my hass instance and having a formatting issue. I am using a customized version of the hygge skin. When I click the alarm panel, the modal dialog opens but the buttons only press when they are not on top of a widget (on the lines between the widgets - for example, hitting the 8 only works if I touch it right between the “Garage Side Door” and “Patio Door” sensors. Red arrows bad, green good) I have played with the opacity and rgba settings on different classes and can’t seem to get it. Any suggestions? Here are a couple of screen shots as well as my dashboard.css.
Also, the 1, 2, 3 work fine over the default widgets. The numbers over sensors and scenes have issues. The 4 works fine over the weather widget, but the problem starts in the bottom half over the sensor.
html {
  font-size: 100%;
  -webkit-text-size-adjust: 100%;
  -ms-text-size-adjust: 100%;
  padding: 0;
body {
  overflow: hidden;
  background: transparent url(/custom_css/home/img/house1.JPG);
  background-repeat: no-repeat;
  background-attachment: fixed;
  background-size: 105%;
  background-position: center;
  margin: 0;
  font-size: 12px;
  color: #fff;
  padding: 0;
  line-height: 1;
  font-family: 'Helvetica Neue', 'Helvetica', 'Open Sans', 'Arial'
b, strong {
  font-weight: bold;
a {
  text-decoration: none;
  color: inherit;
img {
  border: 0;
  -ms-interpolation-mode: bicubic;
  vertical-align: center;
img, object {
  max-width: 100%;
  -webkit-border-radius: 5px;
  -moz-border-radius: 5px;
  border-radius: 5px;}
iframe {
  max-width: 100%;
table {
  border-collapse: collapse;
  border-spacing: 0;
  width: 100%;
td {
  vertical-align: middle;
ul, ol {
  padding: 0;
  margin: 0;
h1, h2, h3, h4, h5, p {
  padding: 0;
  margin: 0;
h1 {
  margin-bottom: 6px;
  text-align: center;
  font-size: 100%;
  font-weight: 200;
h2 {
  font-size: 300%;
  font-weight: 400;
  color: #fff;
h3 {
  font-size: 125%;
  font-weight: 300;
  color: #fff;
input {
  background-color: #444;
  border: none;
h1.title{
  font-weight: bold;
.dashboard_main {
    margin: 0px auto;
.gridster {
  margin: 0px auto;
.icon-background {
  pointer-events: none;
  width: 100%!important;
  height: 100%;
  position: absolute;
  left: 0;
  top: 0;
  opacity: 0.1;
  font-size: 1300%;
  text-align: center;
  margin-top: 82px;
.list-nostyle {
  list-style: none;
.gridster ul {
  list-style: none;
.gs-w {
  width: 100%;
  display: table;
  cursor: pointer;
  z-index: auto !important;
.iframe {
  position: relative;
  overflow: hidden;
.widget {
  padding: 0px 0px;
  text-align: center;
  width: 100%;
  display: table-cell;
  opacity: 0.9;
  background-color: #eee;
  border-radius: 5px;
  z-index: -1;
  .title {
    color: #fff;
  .icon-inactive {
    color: #888;
  .icon-active {
    color: #aaff00;
#container {
  padding-top: 0px;
.modalDialog {
    position: fixed;
    top: 0;
    right: 0;
    bottom: 0;
    left: 0;
    background: rgba(0,0,0,1);
    z-index: 9999;
    opacity:0;
    -webkit-transition: opacity 400ms ease-in;
    -moz-transition: opacity 400ms ease-in;
.modalDialogOpen {
    opacity:0.95;
    pointer-events: auto;
.modalDialogClose {
    opacity:0;
.modalDialog > div {
    width: 275px;
    position: relative;
    margin: 3% auto;
    padding: 5px 20px 13px 20px;
    border-radius: 10px;
    opacity:1;
.modalDialogCloseButton {
    line-height: 50px;
    position: absolute;
    right: -25px;
    text-align: center;
    top: -20px;
    width: 50px;
    font-weight: bold;
    -webkit-border-radius: 25px;
    -moz-border-radius: 25px;
.modalDialogCloseButton:hover { background: #444; }
when i started to build customized widgets i have realized that when you use opaque widgets, you will get problems when you use z-index
and when andrew built the alarm widget, he didnt know that so the alarm widget is using z-index.
solution?
i dont know yet.
at this moment:
  1. dont use opaque widgets if you want to use alarmwidget or
  2. dont use alarmwidget if you want to use opaque widgets
  3. dont try to use 2 alarm widgets in 1 dashboard
or
4) find out a way to get a popup without using z-index and create your own alarm widget or tell Andrew or me how to :wink:
Thanks for the post. I actually went back to the base hygge skin and made all of my changes via the variables.yaml vs. messing with the css and all works now!
you also thanks.
it got me rethinking.
using z-index with opacity might work when the z-index is set in the main css.
so maybe i can use that also for some elements.
