Since last upgrade (but not sure which part was it: the HA upgrade to 116.2, python upgrade to 3.8.6 or appdaemon upgrade to 4.0.5) the mode
widget stopped triggering the configured scripts. I have not been changing neither the dashboard configuration nor scripts nor the entities that are used in those scripts. Those scripts still work ok when triggered from Home Assistant automations or manually from config menu. Below is example of my dashboard configuration:
heating_standby:
widget_type: mode
mode: standby
title: "Off"
icon_on: mdi-power
icon_off: mdi-power
icon_style_active: "color: white"
script: script.heating_standby
entity: input_select.vicare_mode
title_style: "font-size: 150%;"
heating_dhw:
widget_type: mode
mode: dhw
title: Woda
icon_on: mdi-water-pump
icon_off: mdi-water-pump
# icon_style_active: "color: blue"
script: script.heating_dhw
heating_dhwAndHeating:
widget_type: mode
mode: dhwAndHeating
title: Ogrzewanie
icon_on: mdi-calendar-clock
icon_off: mdi-calendar-clock
icon_style_active: "color: orange"
script: script.heating_auto
title_style: "font-size: 130%;"
Any ideas what can go wrong? Nothing shows up in HA log. Is there an appdaemon log I could look at?
update:
I have found an appdaemon service log and it shows the following entry when I try to run those scripts from mode
widget:
2020-10-16 15:13:55.794443 WARNING AppDaemon: Unknown domain (default/script) in call_service from stream
What could that be?
